Forum: VirtualDJ Skins
Topic: #SilverSleek2 - Page: 10
Just to confirm on mine... The time text no longer bounces since I am now using the LCD font. :-)
Very nice skin!
would it be possible at some time when you remove the scratch waves to give me a "beat phraser" somewhere on the skin, that would be awesome!
thanks.
ray
I LIKE it. good job
The showHorizontalSideList is not working on SilverSleek2... It's working on SilverSleek but no SilverSleek2. Also I try to create an shortcut for Max Browser on the keyboard and that's not working.
I got the The showHorizontalSideList to work... Still have not found out how to keyboard shortcut for the Max Browser. Also how do you create a custom bottom for your central panel?
PhantomDeejay wrote :
wickedmix wrote :
how do you activate the full screen browser? cant seem to find the button or option to turn it on.... i know its probably in front of my face but i have looked and looked can't seem to locate it :-(
Currently you can do it with 2 ways:
1) On skin options turn on Browser Toolbox, click on the button on center.
or
2) Map a button on your keyboard/controller with the following command: toggle '$BR_MAX'
great skin! thanks for sharing!
can I map a keyboard/controller to switch between 2 deck and 4 decks layout?what is the script code?
will the 4 deck layout will have 4 fullscratchwaves/dualwaves??maybe in the compact layout?
thank you
thank you
var_equal '@$SilSl2_DecksLayout' 0 ? set '@$SilSl2_DecksLayout' 2 : set '@$SilSl2_DecksLayout' 0
What about switching from video to audio layout
var_equal '@$SilSl2_Center' 1 ? set '@$SilSl2_Center' 2 : set '@$SilSl2_Center' 1
Build 12 is up...
Version 2.12:
Fixed bug on clock and other text zones not rendering correctly on MAC
Fixed bug on Master VU-meter in top bar view. VU-meter will not be visible with external mixer setup anymore.
Added "Auto Cover/Digital" and "Auto Cover/Custom" options on jogs
Added Support for Pioneer DDJ-SP1 and DDJ-SR
Added option to always force 2nd HOTCUE layer to be hotcues 9-16
Awesome and Thanks for such a great skin!!
Any eta on an iPad companion? 😜
Not yet. But it should take a month or so...
Sounds good bro!! I'll be waiting 🙏
Can't quit seem to get the force "hot cue 9-16" to work??
I find it under the misc controller options but when I click on it my 2nd layer stays on "Cue Loop".
I'm using a Pioneer DDJ-SP1.
Thanks for the time and info 👌
Hmmmm
The caption stays the same (bug) but the pads should show hotcues 9-16 ?
Can you confirm ?
Ok after further testing, your right. I do get cue points 9-16 just the text doesn't reflect it on the skin.
Ok so now that we know what the bug is, lol, would it be possible to add the numbered flags for cue points 9-16 as it's hard to see the white on a 15" screen, please?
Other then that this is a great skin 👌
Really advanced users needing so many hotcue's :)
For myself try to keep it under 5 to be able to easily map the 5 hotcue buttons on the HC4500.
I am sorry to lend the thread of this great skin, but if you are using so many hotcue points, do you use these like "remix points" then ?
I use usually have at least 9 per track just to show song structure. normal 64 beat sections, 96 sections. 4 beat breaks etc
where is the battery indicator? Can you please add it? Also how do I can get my logo on jog wheel
38%
