I'm just around the corner... :P
Don't you see me ?
Don't you see me ?
geposted Wed 15 Apr 15 @ 8:28 am
We see you teasing us! :-)
geposted Wed 15 Apr 15 @ 9:02 am
Time for a poll!!!
Which controllers would you like to see their pads supported ?
Please leave your wish...
The only "limitation" is that they must have 8 pads per side... :P
Currently DDJ-SZ and DDJ-SX are already supported.
Since finishing the skin (the way I want it) may take a lot of time, I plan to release the "basic" version and keep updating it until it reaches the point I have in mind.
So for the first release only a few controllers will be supported. Besides SX and SZ I will provide pads support on initial release for only a few more controllers.
So, what's popular these days ?
geposted Wed 15 Apr 15 @ 10:09 am
Dear Phantomdeejay
if possible could you please put some colors behind the 4 (or 2 ,depending on the how many decks are used) channel faders (maybe same color as deck) because it is hard to see the fader position ?
since i mostly look at the screen , it is usefull to know visually at what position the channel fader is , so i can match the volumes (i am not deaf ...it just helps a lot !!)
thank you ,and looking forward for your awesome skin !
Hi Phantom,
Pio DDJ-SP1 would be nice.
Your skin looks great, fantastic work ;o)
geposted Wed 15 Apr 15 @ 10:51 am
Waiting for Numark NS7II :-)
geposted Wed 15 Apr 15 @ 11:04 am
Beautiful skin! Can't wait to start using this!
geposted Wed 15 Apr 15 @ 11:20 am
music234 wrote :
Hi Phantom,
Yup DDJ SP1 please and also instead of the hot loops can you make the 2nd layer cue points 9-16 please??
I asked Bob if he could do this on his SP1 skin and he did so that gives me access to 16 cue points per track.
I've never used the hot loops as it's just another way of doing slip mode.
geposted Wed 15 Apr 15 @ 11:48 am
That's already present on DDJ-SX mode.
I will check if I make a "hack" mode for you... :P
geposted Wed 15 Apr 15 @ 12:08 pm
That would be awesome!!
Like I said hot loops are pointless for me because I'd just use slip mode but yes it would be most appreciated if you could do that 🙏
geposted Wed 15 Apr 15 @ 1:35 pm
Reloop terminalmix8 por favor gracias
geposted Wed 15 Apr 15 @ 1:53 pm
if you could add the, pioneer DDJ-SR that would be great !! thanks
geposted Wed 15 Apr 15 @ 2:07 pm
can you add the numark NV pleeez?...and @ "Beat" @ 16 cues ...not a bad idea ....but why not hot cues.thats what I've used since it was scripted in the xponent map...
geposted Wed 15 Apr 15 @ 3:22 pm
Yeah Fred that's what I'm talking about, lol! So on the first layer you have "HOT CUES" 1-8 and on the 2nd layer (normally would be hot loops) you have "HOT CUES" 9-16..
geposted Wed 15 Apr 15 @ 6:53 pm
Read the entire thread hoping that when I got to the end I would discover that it had been approved and uploaded.
Any chance of a version like this?
geposted Sun 19 Apr 15 @ 4:57 pm
PhantomDeejay wrote :
2 Decks Video:
As I said in the past, almost everything in this skin is modular and "optional"
There are no standard "views". You can turn on/off things and produce the view you want... The total amount of combinations that can be used has not been calculated yet, but a quick estimation makes it more than 150
Here ya go Charlie.
geposted Sun 19 Apr 15 @ 5:35 pm
Yes, "Cloned" decks are an option, but I mostly have demonstrated "Mirror" view...
Patience people! It will be ready to download really soon!
geposted Mon 20 Apr 15 @ 2:31 am
Is it possible to give the Hot Cue points colors and give the pads on my SZ the same colors? Or is this a limitation of VDJ?
geposted Mon 20 Apr 15 @ 2:47 am
It is, but for the moment they would have to be "fixed" colors...
This means that Hotcue 1 would always be red, hotcue 2 would always be orange, hotcue 3 would always be green e.t.c.
geposted Mon 20 Apr 15 @ 6:25 am
