Forum: Old versions
Topic: More F1 Questions
Got the recording and size stuff down, as well as opening the edit menu. Is there a command to add a recording from the browser to the sampler bank, then assign a group to it? Also posted a while back about using the filter section to actually filter the samples.
Looking to do all this without using the mouse.
Other than that, I haven't found much wrong.
geposted Fri 06 Feb 15 @ 4:54 pm
No. Unfortunately you can't do this at the moment because there are not such actions available.
Also you can't filter the samples. You can only filter the entire deck they play from
Are there plans to implement said actions in the future? Wishlist post?
And OK. I kinda figured as much. I will adapt. Won't be hard! Just having fun with mappings!
What would the command be to map FILTER 4 to activate and modulate the filter on Deck 4? Tried using activate_filter deck 4, but no luck.
Not sure if the lack of a button to turn it on/off will be an issue.
deck 4 filter
should be mapped to a knob if you want to control the Filter on deck 4.
By default filter is activated its not at 12 o clock position (OFF) and on when in all other positions.
You can also assign a button as ..
deck 4 filter_activate
which would help if you want to turn off the filter without returning to the Off position.
Got the knob to work. Only controls the filter on Deck 4 audio. Nothing on the samples.
You've assigned the output of the sampler to deck 4?
Yes.
Tried it with all 4 decks. Filter works on the deck, but not on the sampler.
Any advice?
