Topic: Slip Mode Bug [RESOLVED]
ChreecePRO (OEM)Member since 2014
The program is very stable now, thank to the hard working Atomix's programmers.
Althought i'm finding every time a new glitch...
If the "SLIP MODE" is on, when a fresh track is loaded in that deck, the mode activates causing the track to be played in the background, so if you press PLAY the track starts not from the cue point, but from the point that has reached during this background playback...
It should be activated only when the Play button is pressed and not on load...
geposted Mon 09 Feb 15 @ 7:27 am
I can't reproduce here.
Hitting CUE always stop the track and resets Slip_Mode (Meaning that it starts counting once you press play again)
Also loading a track while slip_mode is active, does not start "slipping" until you hit play...
geposted Mon 09 Feb 15 @ 7:37 am
Mapping issue in DDJ-SZ??? I haven't try it without the controller...
geposted Mon 09 Feb 15 @ 7:48 am
Aaah. You're testing with SZ... I believe that's the way Pioneer asked for the controller to work...
I tested without any controller connected ;)
geposted Mon 09 Feb 15 @ 8:06 am
I don't think that pioneer wants that behaviour (it doesn't help in any way). Bevore the SZ i had the CDJ-900 with the slip mode, and that's not how it worked...
geposted Mon 09 Feb 15 @ 8:18 am
Indeed the assigned actions to the PLAY button for the Slip mode is modified to meet Pioneer's requirements.
Pioneer : "Would it be possible to activate SLIP in SLIP mode even when pressing the PLAY button to PAUSE? "
geposted Mon 09 Feb 15 @ 1:01 pm
Yes DJ Dad that's how it should work, but now the SLIP mode works as soon as you load the track! Pressing pause during the playback is something else and also, an expected behaviour for the SLIP MODE to work...
geposted Mon 09 Feb 15 @ 2:00 pm
can u try to modify the BROWSE_LOAD key as ..
slip off & browser_enter
This should resolve the issue when the track is loaded from the SZ
geposted Mon 09 Feb 15 @ 3:21 pm
Thanks DJ DAD I'll give it a try...
geposted Mon 09 Feb 15 @ 11:41 pm
In next beta build , slip action will be turned off when a new track is loaded (regardless the loading way, so the modified action will not be necessary)
geposted Mon 16 Feb 15 @ 3:50 pm
Great!
geposted Tue 17 Feb 15 @ 2:49 am
SlutzkyPRO InfinityMember since 2008
"In next beta build , slip action will be turned off when a new track is loaded (regardless the loading way, so the modified action will not be necessary) "
Good News!!!
Thanks
geposted Sat 21 Feb 15 @ 7:58 am
This is already available.
Topic marked as Resolved.
geposted Sun 22 Feb 15 @ 6:23 pm
