When i make adjustments in the poi editor, the next time i start
up VDJ8 nothing seemt to be saved.
How can i keep those poi's. It's very important to make good automix
sessions.
Grtz John
sessions.
Grtz John
geposted Thu 12 Feb 15 @ 3:13 pm
Hi John,
I can't seem to check what you're saying here man?
If I make any changes in the poi editor they always get saved, if I play with the AM editor it's a whole different ball game.
so whats happening, what r u doin, what do you want to happen?
an old entertainer
ray
an old entertainer
ray
geposted Thu 12 Feb 15 @ 5:33 pm
Hi raypitman,
I want to set automixpoint in the poi editor so i can control my automixes.
However when i restart VDJ8 all the changes i have made are gone.
I don't know if VDJ causes this problem or maybe WIndows8.
Perhaps an option in VDJ that isn't correct or something like that.
geposted Fri 13 Feb 15 @ 3:51 am
With advanced options enabled, search for "readonly" Is it set to yes ?
Also, if you set a "regular" hotcue outside poi editor, does it get saved when you restart the program ?
If not, then you may need to check NTFS file permissions on your database.
geposted Fri 13 Feb 15 @ 6:30 am
thanks PhantomDeejay,
It was the indeed the file permissions that were set to read only.
Now it works.
Grtz John
Now it works.
Grtz John
geposted Fri 13 Feb 15 @ 1:54 pm
