Topic: Scrollbar seeking w/mouse
Is it possible to add scroll-bar behavior like it was in VDJ7? Actually clicking above or below sliding buttons jumps rapidly to position I've just clicked instead one page up or down. With huge databases those jumps are to aggressive even if I try to make it precise. It is really disturbing to switch between touch pad and keyboard Page Up/Down just to pick something. Some config setting to set it to classical one page jump will be appreciated. Generally it would be great to change that behavior for all sliders while now sidelist slider works exactly the same way.
geposted Thu 12 Feb 15 @ 6:57 pm
