Hallo,
last Night the Autoplay dont like me a secondtime.
It plays not the next Song in the List.
It plays the next Song after the Song who i play this evening before a secondtime.
This was realy bad.
I hope you fix it a.s.a.p.
LG Bobby
from Germany
This was realy bad.
LG Bobby
from Germany
geposted Fri 13 Feb 15 @ 6:02 am
Hi Bobby,
do you have the repeat option turned on or off?
sound like it's off, that's why it's skipping the tracks that have already been played ... just a guess.
lg
ray
lg
ray
geposted Fri 13 Feb 15 @ 6:51 am
raypitman wrote :
Hi Bobby,
lg
ray
lg
ray
repeat option turned off !!
Last play removed on
Automix on
Will Play:
Song 1 (Sampler)
Song 2
Song 3
Song 1 (Sampler)
Song 5
Song 6
Automix Play VD 8
Song 1
Song 2
Song 3
Song 5
Song 6
Automix Play VD 7
Song 1
Song 2
Song 3
Song 1
Song 5
Song 6
VD 7 removed last played Song
< Last play removed > yes
VD 8 removed or jump to next not played Song without remove all played Song
That`s the Problem
LG Bobby
geposted Fri 13 Feb 15 @ 9:02 am
ok, I can't get my head around that one unless it's being caused by the length of the HistoryDelay being longer than the sampler track.
sorry i couldn't help
lg
ray
lg
ray
geposted Fri 13 Feb 15 @ 9:18 am
which build do you use ?
geposted Fri 13 Feb 15 @ 10:27 am
2139.. it's in the heading :)
geposted Fri 13 Feb 15 @ 10:57 am
I still think that the repeat option has to be turned on
geposted Fri 13 Feb 15 @ 11:05 am
At least seems legit.
geposted Fri 13 Feb 15 @ 1:54 pm
Nein, siehe oben,
VD 7 hat immer nur das zuletzt gespielte aus der Playlist gelöscht.
VD 8 (normal geladen) spielt den Song 1, überspringt alle anderen bis Position des doppelten Song 1 ( löscht ihn auch), lässt ungespielte aus und spielt bei Song4 weiter.
LG Bobby
geposted Fri 13 Feb 15 @ 2:33 pm
Ok. I can confirm it, wierd behaviour, I never noticed it before.
to test it
put 5 tracks into AM, repeat the first track at pos 3 and watch what happens. It only seems to happen with the option Auto Removed played set to on.
curious.
sorry for doubting you Bobby.
I just checked it on build 2151
one for the devs I think
to test it
curious.
geposted Fri 13 Feb 15 @ 5:39 pm
Yes,
only with option:
Auto Removed played on,
ist the Problem,
LG Bobby
only with option:
ist the Problem,
LG Bobby
geposted Mon 16 Feb 15 @ 11:16 am
