Topic: where is the "fix database" option?
I have deleted 100's of videos recently (most of them for better quality replacements) - I've noticed that the "live feedback" sometimes recommends some of the videos that I have "file, deleted" from the system. Does this mean that the database is retaining information about the old files that don't exist anymore?? If so, I would like the version7 function to "fix" the database and erase redundant data please.
geposted Tue 17 Feb 15 @ 1:54 am
Very bottom left corner, tiny little dot, database>remove missing tracks
geposted Tue 17 Feb 15 @ 2:00 am
Live feedback is collecting track info online and then feeding the info back to you as you play different tracks.
if youve deleted tracks, live feedback has no way of knowing this.
It will eventually pick up on the fact that youre playing different tracks after "current playing" and start suggesting the newer tracks.
geposted Tue 17 Feb 15 @ 8:31 pm
