Forum: Addons
Topic: History Converter - Page: 2
Hi Pachn,
Would it be possible to have the year and comment fields added too?
Thank you
Keith
I'll have a look ;)
Version 1.3.6.0 online
- added year and comment field
Any idea when this is likely to come to Mac. Lots of customers request copies of their playlists after the event and I have no way of converting the history file without a windows PC.
Thanks
If you only want a blank text list of the event, you could open the tracklist file wit a text editor.
You will find that file in your history folder.
Just using your addon but im finding errors in the list the file in VDJ has 86 entries but the CSV / XML files only have 65 any idea to why? i'm using windows10 if thats any help
thanks in advanced
The only reason I can think of at the moment is that a file can not be found at the filepath stored in the history file.
