Build 1785.650 was the last version of VDJ 8 to work with my Denon MC-6000 mk 1 midi controller. Every build since then crashes VDJ completely as soon as I click the configure button.
Also, on 1785.650, karaoke lags badly. The lyrics change colour very jerkily, and the screen lags behind the music.
When doing karaoke, I have to revert to using VDJ 7. This is not ideal, as I really like the audio quality in VDJ 8.
Is there a bug in later builds that affects my Denon MC-6000? I really want to upgrade.
geposted Tue 17 Feb 15 @ 9:11 am
1785? What is the last build you have tried?
geposted Tue 17 Feb 15 @ 9:16 am
I suggest you to try the last build (now official it's 2144). I work with this release (and previous) with DN-MC6000 MK1 (on Windows 8.1 Platform) and no problem.
If your problem persist, I suggest you to delete the configuration file, so it can "rebuild" with latest settings on first run.
Also, I suggest You to delete the plug-in from version 7: this kind of plug-in may several interfer with correct working of VDJ 8.
geposted Tue 17 Feb 15 @ 10:23 am
Absolutely no issues with the current build and my Denon Mc6000 controller.
geposted Wed 18 Feb 15 @ 7:47 am
Yes working well for me with both the standard and mc6000 skins
geposted Thu 19 Feb 15 @ 7:10 am
