-fix %Pcamelot to change as pitch changes
-Export option for playlists added to copy files all the files in the playlist
-Sampler output deck stored in config
-Sampler option added to apply deck effects to sampler output
-Slip disabled on loading new track
-Scratch wave default cue marker color made more clear
-Fix touch-screen difficulty to select multiple files using ctrl or shift
-Fix sidelist/automix getting cleared when updating
-Fix midi reconnection issue that could cause controller leds to stop working
-Year now stored when saving mp4 tags
-fix shatter transition block size setting whilst not selected
-fix skin <window> element opening behind main VDJ interface on Windows
-improve support for older capture cards in camera plugin
-Fix sampler sound issue when Apply Deck Effects is active....OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM.png
geposted Tue 17 Feb 15 @ 8:59 pm
Thanks.
This has already been reported here:
http://www.virtualdj.com/forums/198539/Beta_Builds_Regression_Bugs/BUILD_2156_-_BETA.html
I'll close this post to keep things simple.
geposted Wed 18 Feb 15 @ 6:05 am
