is there a way that in the next few updates they can make it so you could go into config and pick the colors of the waveforms I find some times the skin ones are hard to see and would love to be able to select the colors of the player to match by selecting out of a few choices. sometimes in day light its hard to see. Thanks in advance.
geposted Wed 18 Feb 15 @ 7:02 pm
Which waveforms? Rhythmwave, songpos, scratchwave?
geposted Wed 18 Feb 15 @ 7:06 pm
all of them. I want to be able to change them with a click of a button. In outdoor events its hard to see some times.
geposted Tue 24 Feb 15 @ 8:59 pm
Except rythmwaves, the other waves (scratch and progress) allready have 3 presets available on settings:
Monochrome, Ultra-Blue, Infra-Red and Neutral.
There's also the "Per-Deck" setting which uses Ultra-Blue for left decks and Infra-Red for right decks.
geposted Thu 26 Feb 15 @ 1:43 pm
Yes, and a button can be scripted to switch between them (I did this on a skin for myself).
It would be better though if we had a little more control of the colours for each deck, rather than the choice affecting all of them.
Best would be the ability to set your own colours for all waves.
geposted Thu 26 Feb 15 @ 2:03 pm
Thanks. Im always learning. It only takes one question or idea to come up with something awesome.
geposted Mon 02 Mar 15 @ 2:46 pm
