Topic: Sampler Output On DDJ-SZ
SlutzkyPRO InfinityMember since 2008
Hi
I have MacBook Pro With Windows 7 64BIT + DDJ-SZ.
All Is Ok with VDJ 7 For Many Years.
With VDJ8 I Configured The Sampler To Work On DDJ-SZ Channel 9 + 10
All Ok but Now I Cant Control The Volume With The Sampler Knob Any More.
It used To Work until I Reinstalled VDj8 (To Try And Fix other Problems :()
Anyone?
geposted Thu 19 Feb 15 @ 5:52 pm
I test it Again With VDJ7 And All OK
Is There Anything We Can Do TO Make It Work In VDJ8?
geposted Sat 21 Feb 15 @ 7:59 am
my guess is the volume control for samples is not mapped to channel 9 and 10 therefore cant control it
why did u switch it from the default?
i think the solution will require you to map the sample volume control to the channel 9/10 volume
good luck
geposted Sat 21 Feb 15 @ 8:17 am
How Can I Map It?
I Cant Seem To Find The Correct parameters...
I Check in VDJ7 Ant There Its not Midi Mapped but Directly Mapped Thru The Sound Settings.
Please Help.
geposted Mon 23 Feb 15 @ 6:20 pm
No need to map anything special.
I just tried to route Sampler to Outs 9.10
and i can properly control the Master Volume of the Sampler by using the SAMPLER VOL knob at the left side of the DDJ-SZ (with the factory default mapping)
Btw, you are not referred to the DDJ-SZ hardware Oscillator , right ?
geposted Mon 23 Feb 15 @ 7:52 pm
That's Exactly What I Did Ant it Doesn't Work With My VDJ8...
I Hear The Sound But Not With The Sampler Knob...
geposted Tue 24 Feb 15 @ 6:49 am
in there a way to check and see in the defanition file of the vdj? i guess that somthing is wrong with the routing of the 9+10 channels output...
as i said before i hear it thrue the mail channels not the sampler even that i configure the channels to be 9+10
in vdj7 it works with no configuration needed...
please advize.
geposted Fri 27 Feb 15 @ 5:18 am
Please post pictures of your configuration (same areas as djdad, but with your own settings).
geposted Fri 27 Feb 15 @ 5:51 am
The SZ Is not Connected...
geposted Fri 27 Feb 15 @ 6:51 am
please advize.
Definitions have nothing to do with the audio routing.
Can you please post a screenshot of your SZ ASIO driver settings ?
Please include all the first 3 tabs.
geposted Fri 27 Feb 15 @ 7:53 am
Here You Go:
geposted Fri 27 Feb 15 @ 12:16 pm
Any New Idea's?
geposted Tue 03 Mar 15 @ 8:33 pm
I will try on MAC this afternoon (about noon your time) and I will let you know...
On Windows it works if everything is set according to your pics
geposted Wed 04 Mar 15 @ 12:50 am
im using a mac but with windows 7 on boot camp.
please let me know if you get somthing
thanks
geposted Thu 05 Mar 15 @ 3:08 pm
Bootcamp could be the reason of not working on your side. Sometimes drivers need to be installed on the Mac side AND/OR the Windows side. Not sure what is the case for the Pioneer DDJ-SZ drivers here.
Dont have Bootcamp on my Mac either , so cant help by trying to reproduce it.
Btw, on the pics you have posted above, i noticed a message "Not Connected" inside the Pioneer Utiltity. Is this what you get when the unit is connected ?
geposted Fri 06 Mar 15 @ 1:53 am
Sorry For The Slow Response... I Was In The US For The Last Week...
As For The "Not Connected", When I Connect The SZ Its Ok :)
I Use Boot Camp For More The 8 Yrs. With no Problem...
When I Use VDJ7 All Ok With The Mapping.
geposted Sat 14 Mar 15 @ 4:58 pm
