Topic: Compatibilty folder
My compatibility folder shows empty when I click on it. worked fine before. I using VDJ8
geposted Fri 20 Feb 15 @ 3:49 pm
What is the scope of that filter folder?
Just do a rightclick on that folder, choose edit.
You'll see the scope in the dropdown box on the right side of the edit window.
geposted Mon 23 Feb 15 @ 5:32 am
