I enclose the Crashreport. it happens always if i try to do a batch scan for BPM and tag for a whole Drive. after a few scanned mp3 files vdj crashes.
I use it on a MacBook pro latest OS and latest VDJ version. If i try to scan for BPM and tags manually reverting is fine. Even if i select a group of files it works. On my Windowsversion the using same files and external disk everything works. The Problem occurs only with the Mac version.
0 libsystem_kernel.dylib 0x00007fff8b268286 __pthread_kill + 10
1 libsystem_c.dylib 0x00007fff96243b53 abort + 129
2 libc++abi.dylib 0x00007fff955cda21 abort_message + 257
3 libc++abi.dylib 0x00007fff955f59b9 default_terminate_handler() + 243
4 libobjc.A.dylib 0x00007fff8ba7e7eb _objc_terminate() + 124
5 libc++abi.dylib 0x00007fff955f30a1 std::__terminate(void (*)()) + 8
6 libc++abi.dylib 0x00007fff955f2b30 __cxa_throw + 121
7 libc++.1.dylib 0x00007fff8a85c47e operator new(unsigned long) + 94
8 com.atomixproductions.virtualdj 0x0000000107010a28 0x106d36000 + 2992680
9 com.atomixproductions.virtualdj 0x0000000106d451a2 0x106d36000 + 61858
10 com.atomixproductions.virtualdj 0x0000000107010e96 0x106d36000 + 2993814
11 com.atomixproductions.virtualdj 0x0000000107097fcb 0x106d36000 + 3547083
12 com.atomixproductions.virtualdj 0x0000000106d3ea8d 0x106d36000 + 35469
13 com.atomixproductions.virtualdj 0x0000000106d3ea61 0x106d36000 + 35425
14 libsystem_pthread.dylib 0x00007fff8e422268 _pthread_body + 131
15 libsystem_pthread.dylib 0x00007fff8e4221e5 _pthread_start + 176
16 libsystem_pthread.dylib 0x00007fff8e42041d thread_start + 13
geposted Sat 21 Feb 15 @ 4:07 am
We would need to have these files which cause the crash.
Would be great if you locate them and upload the file/s to dropbox.
You can share this link with me per PM :-)
geposted Sat 21 Feb 15 @ 8:41 am
it crashes with any mp3 file when doing Batchscanning. But if scanning the same files manually it works. The same files from the same HDD, Batchscanning with the VDJ Windows Version works fine.. its not a problem of some mp3 files it is a general problem.
geposted Tue 24 Feb 15 @ 11:48 am
How exactly do you select an entire drive for scanning?
geposted Wed 25 Feb 15 @ 12:45 am
For example: Folder Unscanned Files, right click, batch, right click scann for tags and BPM. after scanning a few files VDJ aborts - see Crash log..
geposted Wed 25 Feb 15 @ 1:25 pm
Must be a corrupt file then.
Can you track down the file?
geposted Thu 26 Feb 15 @ 3:34 am
A corrupt file that works fine with the Windows version?
geposted Thu 26 Feb 15 @ 6:42 am
EDIT:
Hm, ok, you got a point...
geposted Thu 26 Feb 15 @ 6:54 am
It crashed with any mp3 file while batch scanning. When select a few files manually no problem..same files!!
geposted Thu 26 Feb 15 @ 7:15 am
You said unscanned, so possibly a problem batch-scanning filter folders then.
Did you try selecting a regular folder instead and does it still crash then?
geposted Thu 26 Feb 15 @ 7:19 am
I tryed to select the "music-root folder and click batsch scanning for tags and bpm after a few scans it crashed. If i try to select a specific folder containing 100 or 150 Files it works mostly but not always...
geposted Fri 27 Feb 15 @ 8:46 am
Here is the latest crashreport:
Thread 15 Crashed:
0 libsystem_kernel.dylib 0x00007fff8a097286 __pthread_kill + 10
1 libsystem_c.dylib 0x00007fff95072b53 abort + 129
2 libc++abi.dylib 0x00007fff943fca21 abort_message + 257
3 libc++abi.dylib 0x00007fff944249b9 default_terminate_handler() + 243
4 libobjc.A.dylib 0x00007fff8a8ad7eb _objc_terminate() + 124
5 libc++abi.dylib 0x00007fff944220a1 std::__terminate(void (*)()) + 8
6 libc++abi.dylib 0x00007fff94421b30 __cxa_throw + 121
7 libc++.1.dylib 0x00007fff8968b47e operator new(unsigned long) + 94
8 com.atomixproductions.virtualdj 0x000000010fa55a28 0x10f77b000 + 2992680
9 com.atomixproductions.virtualdj 0x000000010f78a1a2 0x10f77b000 + 61858
10 com.atomixproductions.virtualdj 0x000000010fa55e96 0x10f77b000 + 2993814
11 com.atomixproductions.virtualdj 0x000000010fadcfcb 0x10f77b000 + 3547083
12 com.atomixproductions.virtualdj 0x000000010f783a8d 0x10f77b000 + 35469
13 com.atomixproductions.virtualdj 0x000000010f783a61 0x10f77b000 + 35425
14 libsystem_pthread.dylib 0x00007fff8d251268 _pthread_body + 131
15 libsystem_pthread.dylib 0x00007fff8d2511e5 _pthread_start + 176
16 libsystem_pthread.dylib 0x00007fff8d24f41d thread_start + 13
Thread 15 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x0000000116e37748 rdx: 0x0000000000000000
rdi: 0x00000000000114df rsi: 0x0000000000000006 rbp: 0x0000000116e37770 rsp: 0x0000000116e37748
r8: 0x636f6c6c615f6461 r9: 0x00007fff9509cd70 r10: 0x0000000008000000 r11: 0x0000000000000206
r12: 0x0000000116e378d0 r13: 0x000000000601001e r14: 0x0000000116e38000 r15: 0x0000000116e377b0
rip: 0x00007fff8a097286 rfl: 0x0000000000000206 cr2: 0x00007fff79ad5fd8
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Thread 15 Crashed:
Logical CPU: 0
Trap Number: 133
geposted Fri 27 Feb 15 @ 8:57 am
If this will happen to ALL of your mp3's, please be so kind and upload a bunch of it on dropbox or similat.
You can share the link with me by using the PM feature on page side.
Please also use the Quicktime monitor screencast to record what you are doing.
Please add video also to your dropbox content or upload it on youtube.
geposted Sat 28 Feb 15 @ 6:14 am
