and these are my settings for hercules djmk4 using asio4all... (the hercules needs to be set to "WDM" mode before asio4all will work.
geposted Sun 22 Feb 15 @ 3:17 am
Even though i find no reason using ASIO4ALL instead of the Hercules ASIO (unless you explain in what way you get better results), i also see no point posting this in the Version 8 Bugs report forum.
geposted Sun 22 Feb 15 @ 6:22 pm
There is no reason to use Asio4all, The Asio drivers that come with the Hercules work perfect.
geposted Sun 22 Feb 15 @ 9:44 pm
