-Fix regression crash with effects on samples
-Resize and move grab zones allow for visibility
-Small sampler performance improvement
-Fix automix fade point calculation for samplerate other than 44100Hz
geposted Sun 22 Feb 15 @ 4:28 am
This update is not releasing the video out once activated..
pressing CTRL+v just freezes video outputs and cannot re-activate)
will try rollback to previous build...
[edit:] rolling back didnt help so its something to do with my system then...?
geposted Sun 22 Feb 15 @ 4:33 pm
re-installed system (as it needed a nice clean-out) but still vdj not releasing video out (from 2nd monitor)
geposted Sun 22 Feb 15 @ 8:32 pm
Ape format loading is error,Almost all the same
The music loading Only 15 seconds
And the position is Jumped(intermittent)
geposted Sun 22 Feb 15 @ 9:50 pm
When using the edit_singer action mapped to a Novation Dicer, preview video output freezes on the software, but continues playing on the output. All other controllers become unresponsive while pop up window is active. If left open for a little bit of time, whole program becomes unresponsive and must be force quit.
Mac OS X Yosemite with all current updates. Connected controllers: MC-6000, Dicers, X1mk2, F1, and X1.
geposted Sun 22 Feb 15 @ 10:10 pm
MAC OSX Yosemite with Pioneer DDJ SR ->>> I can´t use the Master Volume of the SR Console... but i think, i could it use and change the MasterVolumen in another Build
Skin: DJ Dad - Combat Mirror
geposted Mon 23 Feb 15 @ 7:21 am
I reported this on the other page and got no response.
geposted Mon 23 Feb 15 @ 8:59 am
pitchLock in the settings won't save. After loading a new song or restarting the software it goes back to "no"
I'm on a Mac btw.
I'm on a Mac btw.
geposted Wed 25 Feb 15 @ 9:53 am
