Topic: backspace and blue screen
huttPRO InfinityMember since 2008
Legal copy playing. Right side search ing, use the backspace key it crashes. Left side no problems. . What do you think?
Ray Skyers Looks like all your drivers are not to date... that's an entire system crash and not just software. Could be RAM issue also.... what are your specs? and have you tried a fresh install?
February 20 at 8:21pm · Like · 2
Glenn Henson computer problem not software... thats why you should use a mac... i hope u not @ a gig...
February 20 at 8:22pm · Like · 1
Ray Skyers Also I would debug using the default skin... nothing to do with mac or pc... I have seen many macs fail where PCs survived, once the specs are fine and machine is opimized it doesn't matter
February 20 at 8:24pm · Like · 1
Scott Miser Pc crash! Not software.
February 20 at 8:49pm · Like
Johnnie Johnson the biggest difference between mac and pc is with mac u have less of these situations. u wanna be technically inclined to run pc. if this error is new then u wanna uninstall any new software or do a system restore. it's saying hardware error so it could be anything from your soundcard to your processor to your controller.
February 20 at 10:00pm · Like
Graeme Dunn Or it could be that your fan needs cleaning
February 20 at 10:08pm · Like
Quin Gomes that looks like a ''blue screen of death'' to me. Blue screens are caused by hardware problems and issues with low-level software running in the Windows. So any faulty hardware you may have inside your laptop or drivers not up to date can cause this. ...See More
February 20 at 10:27pm · Edited · Like
Erick Roque ummm Virus .. Blue screen of death
February 20 at 10:24pm · Like
Erick Roque i'm guessing your also using your PC to surf, play games, download, etc... this can also be an issue
February 20 at 10:26pm · Like
Terry Hill More porn!
February 20 at 11:52pm · Like
Isaac Rivas not enough ram
Yesterday at 12:15am · Like
Klaus Mogensen As said above probably a windows or a hw problem - not vdj. And always use default skin for debugging
Yesterday at 12:17am · Like · 1
Chuck Barnhart the hardware that causes the BSOD is typically a memory error... if it is doing on THAT SKIN ONLY... it's an error in the skin coding working with the VDJ software. If it's doing it ON EVERY SKIN, then yes, uodate any applicable audio/video card drivers. Other that, uninstall and re-install VDJ and see where you get.
Yesterday at 1:24am · Like
Chuck Barnhart especially skin suspicious because that's a custom skin AND it's a very specific trigger causing it.
Yesterday at 1:25am · Like
Nathan Gilchrist Erick Roque blue screen of death you're absolutely wrong, blue sceen of death is just blank doesn't have writing on explaining the crash, and yes as everyone as said it's nothing to do with the software, do a fresh install and update all drives
Yesterday at 3:43am · Like
Pesche Rudolf von Rohr disable auto reboot after crash on windows.... and disable auto-update of drivers in windows
Yesterday at 4:30am · Edited · Like
Kevin Johnson BSOD are NOT BLANK ..... They will point you to WHERE the fault occured and a error message .........
Kevin Johnson's photo.
Yesterday at 4:39am · Like · 1
Kevin Johnson Win 8
Ray Skyers Blue screen of death is not blank. It contains useful information
Yesterday at 4:42am · Like
Nathan Gilchrist strange when i had it it gave me nothing but blank
Yesterday at 4:44am · Like
Ray Skyers It depends on your settings in windows. There is a debug option
Yesterday at 4:45am · Like
Joe Bezzina Try it with the default skin and see what happens! If it does not crash it is the skin!
Yesterday at 12:06pm · Like · 1
Jim Hutt Walters update, uninstalled VDJ 8 and 7, reinstalled both and installed Numark NS6 drivers and the problems still exsist. If I repeatly hit the backspace key on either side does the same thing
2 mins · Like
Jim Hutt Walters
Write a comment...
geposted Sun 22 Feb 15 @ 10:07 pm
