Topic: Sonique for 8
ewitlesPRO InfinityMember since 2006
I since removed 7 and all native 7 plug ins and stuff, and did a fresh install of 8. Did not want any 7 baggage.
Where is the Sonique for 8? Don't want to mess things up.
Thanks!!!
geposted Tue 24 Feb 15 @ 12:29 pm
You can stick the SVP files straight into the VideoEffect or Visualisations folder.
geposted Tue 24 Feb 15 @ 3:17 pm
No luck for Mac though, correct?
geposted Tue 24 Feb 15 @ 4:29 pm
Sonique files are actually DLLs, so won't work on a Mac.
geposted Tue 24 Feb 15 @ 5:04 pm
What would be the best folder for those files?
geposted Tue 24 Feb 15 @ 7:40 pm
Video effects folder 😳
geposted Tue 24 Feb 15 @ 9:24 pm
If you want to be able to use them as audioOnlyVisualisations, then Visualisations. Otherwise it's user preference.
Personally I prefer to keep anything that generates content in Visualisations, and things that modify content in VideoEffect.
geposted Wed 25 Feb 15 @ 10:25 am
