Forum: VirtualDJ Skins
Topic: help with VDJ script /syntax
Hello,
I really like VDJ8 but I can't use it because database transfer of my old cues from VDJ7 to VDJ8 is sometimes not precise. Cues are exactly alligned with grid in VDJ7 but not in VDJ8.
Anyway I love showing value "beat fromnextcue". I would like to put it inside .xml file and use with VDJ7.
Matematically it always should have been the smallest positive value from all the cues of the song. Also integer value would be appreciated. I spent several nights on it but I have failed. Only "%Btocuen" and "%Bfromcuen"is working. But this is always only one cue.
I believe it can be quite easy for some of you. Easier than understand my English I suppose :)
Thanx for your effort and time.
geposted Thu 26 Feb 15 @ 2:48 pm
Nobody answers....
Everybody talking about left-right wave movement...
Probably my question is stupid...
geposted Thu 05 Mar 15 @ 5:47 pm
so format="%Btocue1", format="%Btocue2" etc dont work for you ?
geposted Fri 06 Mar 15 @ 5:24 pm
Thank You djDad for replay,
format "%Btocue1" or "%Btocuen" while n=2, 3, 4 etc is working in both VDJ7 and VDJ8.
My aim is to see "%Btonextcue" or "%Bfromnextcue" which works ONLY in VDJ8. I would like use this feature also in VDJ7, but it does not work.
I tried to overcome it by some conditions but I failed.
geposted Sat 07 Mar 15 @ 8:13 am
Yes, it's not possible in 7. Only it 8.
As 7 is no longer receiving updates, this is unlikely to be added.
geposted Sat 07 Mar 15 @ 8:26 am
