in version 7 i used the shortcut 'i' to do 'browsed_file_info' (= open tag editor)
i could open the 'tag editor' in this way from the databaselist (or sidelist) in V7, but this does not seem to work in V8 altough the function still exits
geposted Fri 27 Feb 15 @ 3:29 am
It works OK here, both as a keyboard shortcut on the 'i' key and as a custom button (on the skin).
I can pop up the tag editor from a track highlighted in the main browser, the automix list and the sidelist.
How are you entering the script?
geposted Fri 27 Feb 15 @ 4:21 am
Hi, thanks for your reply
I found the reason why this did not work.
The setting 'BrowserSearchByFirstLetter' caused this, it was yes. After changing to No it works as expected.
geposted Mon 02 Mar 15 @ 4:11 am
