Topic: Virtual Dj 8 updates
Someone one told me where to go to set it so it will update automatically. I had to reset virtual and I no longer am getting updates. Where do I go to change the setting for updates?
geposted Fri 27 Feb 15 @ 7:42 pm
First there's "get beta builds" option Here
Which I imagine hasn't been reset (just including this to be complete)
And then there's inside V8: Show advanced options, Search "getBetaBuilds" set this to yes.
geposted Fri 27 Feb 15 @ 8:15 pm
There's also checkUpdates in config (which presumably is for non-beta updates).
geposted Sat 28 Feb 15 @ 5:14 am
