Topic: Re-arranging the Sidelist/automix/karaoke/etc
when your sidelist is full and you want to ADD tracks to your list but you want to add it to the bottom of the list (for example) you cannot drag your new file and scroll down (with a mouse OR touchscreen)
Im expecting the list to start scrolling up or down if i drag a track there so that i can find where i would like to drop my file.
the same happens IF i want to re-arrange the list and need to move tracks UP (or down)
(instead i have to drag up, drop, scroll the list down, drag up, drop...)
geposted Sun 01 Mar 15 @ 7:15 pm
On a multi-touch screen cant you just use the scrollbar at the same time ?
what you describe/request is sort of a mouse-behavior where all you can use is a single pointing/controlling device and probably makes sense to have, but thats more a request rather than a bug.
geposted Mon 02 Mar 15 @ 4:49 am
Ye I should've mentioned non multi-touch, can only do one thing at once with my touchpanel.
Windows explorer can do this, please can the powers that be let virtualdj do this too??
geposted Mon 02 Mar 15 @ 9:40 am
