If i need to release the video-out on 2nd monitor back to the desktop normally i can press [ctrl] V or click video toggle in a skin.
however suddenly virtualdj is not releasing the video, instead its freezing the video output and the only way to recover from this is to restart virtualdj :(
ive tried rolling back a few beta updates AND ive even re-formatted my PC (as it did need it for other reasons)
Also treed flushing out the settings xml file too to mo avail
Is this a bug or is there anything else i could try??
geposted Sun 01 Mar 15 @ 7:20 pm
I dont think there is a bug, since i can properly turn on/off video with either the action or from skin.
Is there any specific Plugin (Video Effect or visualization) running when you re trying to do this ?
geposted Mon 02 Mar 15 @ 3:39 am
I have this problem if videoforcefullscreen is set to 1. If it is 0, I can enable and disable the video.
geposted Mon 02 Mar 15 @ 9:11 am
blckjck wrote :
if videoforcefullscreen is set to 0, I can enable and disable the video.
Thanks blckjck this helped me :)
geposted Mon 02 Mar 15 @ 7:06 pm
No problem
Keep in mind that I had full screen on 1 to lessen tearing in my videos. Watch out for playback issues.
geposted Tue 03 Mar 15 @ 12:28 am
