Hey guys,
I was trying to install some effects on my Virtual dj LE 7.4 and even though it was in the right folder, it did not show in the app. I deleted the app and all the folders and redownloaded everything. Now i have the VDJ app but i do not have its folder on my computer...
Please help i know its probably a noob question but i have no idea what i did.
Thanks in advance
Thanks in advance
geposted Sun 01 Mar 15 @ 9:05 pm
Some effects are for pro users only your version will not allow you to use the effects you need to buy a pro license to use the effects
geposted Mon 02 Mar 15 @ 9:17 am
Sorry, VirtualDJ LE 7.4 is limited software and does not support using custom effects except while the full VirtualDJ Pro trial is active.
If you would like to use custom effects then you will need to upgrade/subscribe to the full VirtualDJ Pro or purchase a VirtualDJ v8 Plus license for your controller.
geposted Tue 03 Mar 15 @ 8:37 am
