Topic: bugs in vdj8 songs loading
hello i use vdj and never had a problam but now evetime i load a song it says error on the deck im loading a song form the internet. vdj gets there songs from groveshark.com so i wint there and looked it up the song and it works fine but when i go to vdj8 and load a song on my deck it dose not work
it works with some songs but not all of them plz fix thanks
geposted Tue 03 Mar 15 @ 2:11 pm
What build of v8 are you using?
What colour is the icon of the song you are trying to load?
I suspect you are using build 2139 and trying to load netsearch files (purple icon). These will not work in that build and require you to be running beta version 2144 or later.
geposted Tue 03 Mar 15 @ 2:19 pm
How should I set my options in ContentUnlimited? I get a lot of purple icons and then get errors. What is the remedy to downloading songs continually? Should I Forcedown Audio Files. etc. Is something wrong with my Brower? am using Windows7 Home Premium on my Samsung computer.
geposted Tue 03 Mar 15 @ 9:57 pm
