I'm new to the track cleaner feature. After loading a song in 'track cleaner' I can start to play it but I can't hear anything. I assume there is a simple thing I need to do but as it stands I have no clue what the problem is. Songs play fine normally and all volumes are up.
geposted Tue 03 Mar 15 @ 8:50 pm
Have you set a preview output on your audio config?
geposted Wed 04 Mar 15 @ 2:15 am
That was it. Thanks for the help!!
geposted Mon 09 Mar 15 @ 8:45 pm
How do you do that
geposted Sun 09 Oct 16 @ 8:22 am
I can't here anything out of track cleaner
geposted Wed 25 Jan 17 @ 4:04 am
I'm having trouble too and don't know how to do that.
geposted Sat 01 Apr 17 @ 3:56 pm
Hey guys, I figured this out. In Settings, select the Audio Settings Icons, select your output (Speaker/heaphone,etc.) and then click on the small black + icon on the right side to add another output. Select "Preview" from the drop menu options & boom!
geposted Sun 23 Apr 17 @ 7:28 pm
