When I try to access Settings / Options I am getting a blank window instead of the grey list (options/browser/audio etc).
If I click 'Show Advanced Options' and then click in the window the input boxes show up and tooltips below are displayed, so I know the options are there... I just can't get any text to show up.
Am using latest version build 2139.926 with Windows 8.1 64bit Dell Inspiron Hi-Res screen.
Any ideas?
Any ideas?
geposted Thu 05 Mar 15 @ 2:25 pm
Interesting, is V8 in full screen mode?
geposted Thu 05 Mar 15 @ 2:33 pm
Full screen or windowed, same outcome.
Oh, my laptop is Touchscreen enabled - don't know if that has any bearing on it.
geposted Thu 05 Mar 15 @ 2:39 pm
Perhaps, erm what about screen resolution is that as should be?
And has this problem started recently (did it work in previous builds?)
geposted Thu 05 Mar 15 @ 2:55 pm
Good call.... My native resolution is correct at 3840x2160... But if I drop it down lower to 2048x1152 the grey text DOES now appear...
However the settings box itself is does not scale down and is too big for the screen.
geposted Thu 05 Mar 15 @ 3:04 pm
Ok I think I've helped as much as I can, play around with the resolution so you can at least sort out your options for playing, report any findings and hopefully a member of staff can ask more questions or recommend a fix, or confirm it's a bug on the todo list.
geposted Thu 05 Mar 15 @ 3:11 pm
You're a star. Thank you.
geposted Thu 05 Mar 15 @ 3:12 pm
Normally it shouldnt matter, but try this too..
Right-click on desktop->Personalize
Play around with that option (actually try to set it to the smallest value)
geposted Fri 06 Mar 15 @ 2:12 am
