What is DXVA and would it help if i turned it on??
geposted Thu 05 Mar 15 @ 7:15 pm
Yes it would direct X video acceleration.
geposted Thu 05 Mar 15 @ 7:39 pm
by default its off. so turning it ON would be beneficial??
geposted Fri 06 Mar 15 @ 10:31 am
If you're not having video problems, Why rock the boat? on the other hand if you're curious, do it.
In some cases it improves, in some cases it could worsen performance or it might not have very much effect at all.
Experiment.
Experiment.
geposted Fri 06 Mar 15 @ 10:57 am
