Topic: Selecting multiple files
I apologize if this has been answered already, I couldn't find it. Is there an easy way to select all files in search results? I want to batch write bpm and key tags. I have almost 4000 mp4 files that need tagging and to select them manually would take hours. Thank you for any help you can provide :)
geposted Fri 06 Mar 15 @ 3:25 pm
windows?
ctrl + a
geposted Fri 06 Mar 15 @ 3:41 pm
Ctrl+click adds to group
Click, then shift+Click highlights all entries between clicks.
geposted Fri 06 Mar 15 @ 3:44 pm
Yes, Windows. Thank you so much! I knew it was something simple. It was driving me crazy :)
geposted Fri 06 Mar 15 @ 9:01 pm
No worries, said clicking also works in windows generally, also you can use Ctrl+click to deselect selected items.
geposted Sat 07 Mar 15 @ 5:41 pm
Does anyone know how to select multiple files in MAC OS system?
Thanks in advance.
geposted Thu 03 Dec 20 @ 4:32 am
Almost the same as on windows. Click one file, then shift+click the last file, or click one file, then CMD+click the other files you want to add to the selection. Or CMD+A to select all files.
geposted Thu 03 Dec 20 @ 5:44 am
