Topic: track will only play backwards
areay26PRO InfinityMember since 2014
on loading a track it will only play backwards. fixed on restarting the software virtual dj 8
geposted Sun 08 Mar 15 @ 9:57 am
Somehow you had enabled the reverse (action). Check the mapping file of your controller and keyboard in case you had enabled that by mistake (and be able to disable it next time).
Also, in case you re using a custom skin, there may be a chance the skin has a right-click action to enable/disable this (the default ones dont have this )
geposted Sun 08 Mar 15 @ 6:40 pm
