Hi,
When I drag a song into the playlist, then delete it, and go back to the playlist, it is still there.
geposted Sun 08 Mar 15 @ 11:19 am
this is normal unless you have auto save playlists on
geposted Sun 08 Mar 15 @ 12:33 pm
Will this delete them after they are played though?
So If I play the song or throw it in auto-mix, will it still be in the designated Playlist?
geposted Sun 08 Mar 15 @ 3:06 pm
if the list is saved after they are removed they wont be in it next time
geposted Sun 08 Mar 15 @ 3:50 pm
