I have my Hotcues MixPoints in VDJ8 with the Action Macro for example. 'loop 8' set. VDJ8 ends this loop vöölig unchecked automatically.
Perhaps jump at the back of the loop sometimes jumped just before the HotCue and thus the Action Macro executed a second time, which terminates the loop.
With mauell set loop it is not automatically exit the loop
geposted Mon 09 Mar 15 @ 4:38 am
I don't know your workflow, but you can always use some kind of "security" on your action:
loop 8 ? nothing : loop 8
loop ? nothing : loop 8
e.t.c.
e.t.c.
geposted Mon 09 Mar 15 @ 8:52 am
this is a good idea for a momentary solution. Thank You
geposted Mon 09 Mar 15 @ 9:16 am
