Right click on LoopBe internal MIDI Clock, select MIDI Clock Output, close and restart program, still not remember setting and have to reset.
Win 7 64 bit
VDJ8 build 2162.945
Win 7 64 bit
VDJ8 build 2162.945
geposted Mon 09 Mar 15 @ 10:20 am
Tested and working fine here with both real MIDI devices and loopBe1.
I'd recommend you delete your settings.xml and set things back up again.
geposted Mon 09 Mar 15 @ 5:05 pm
OK, I just tried that and it still doesn't work. Glad I made a backup of settings.xml first! Lots of mods.
Any other thoughts? I go to loopbe under controllers, click once so it's highlighted, right click, then select MIDI Clock output. It places a checkmark there. I go back and check (without closing VDJ) and there's a checkmark. I close the program and restart, there isn't.
geposted Mon 09 Mar 15 @ 5:43 pm
After you close VDJ, open your settings and see if there's any record of the MIDI clock.
Search for midiclockoutput, you should find a line like:
<controller name="SIMPLE_MIDI_0_0" mapper="SIMPLE_MIDI_0_0 - custom mapping" midiclockoutput="yes" />
geposted Mon 09 Mar 15 @ 5:58 pm
This is what I find:
<controller name="SIMPLE_MIDI_0_0" mapper="SIMPLE_MIDI_0_0 - custom mapping (1)"/>
geposted Mon 09 Mar 15 @ 6:07 pm
...when I open the program, select MIDI Clock Output and go read the settings.xml file with the program still open, it still shows the same thing I posted.
geposted Mon 09 Mar 15 @ 6:14 pm
OK, so it hasn't been saved for some reason. If you add it manually in the settings, does it appear when you open VDJ, and does it then persist between restarts?
<controller name="SIMPLE_MIDI_0_0" mapper="SIMPLE_MIDI_0_0 - custom mapping (1)" midiclockoutput="yes"/>
geposted Mon 09 Mar 15 @ 6:15 pm
OK, I added and saved it. I then started VDJ and it was there so that worked, thank you.
geposted Mon 09 Mar 15 @ 6:36 pm
