Well I just noticed VDJ isn't reading my sub-crates in another sub-crate when it comes to reading Serato's crates.
Not sure how long this has been going on but when I open SDJ everything is fine yet VDJ will only read 1 sub-crate deep.
geposted Mon 09 Mar 15 @ 8:10 pm
I tried creating a structure crate 1 which contains crate 2 which contains crate 3, and it correctly shows 3 levels in vdj for me.
geposted Tue 10 Mar 15 @ 1:38 am
Can you try with an external drive please??
geposted Tue 10 Mar 15 @ 3:09 am
Anybody having problems with sub-crates in a sub-crate??
Mine are showing up but I try to expand them nothing happens. It's like VDJ thinks the crate is empty.
geposted Tue 10 Mar 15 @ 9:49 am
Can u give an example ?
E.g. sub-crates that only contain files from an external HD ??
geposted Tue 10 Mar 15 @ 10:28 am
It goes like this
Main Crate-
Sub-Crate(albums)-
Sub-Crate(Singles)
The albums crate shows up but the singles crate which is inside the albums crate doesn't show up. When I open SDJ its there and opens just fine but for some reason VDJ won't open it.
As Im sitting here looking its the ONLY sub-crate that VDJ won't open??
Main Crate-
Sub-Crate(albums)-
Sub-Crate(Singles)
geposted Tue 10 Mar 15 @ 10:44 am
Trying to reproduce here, but cant.
So ..
- the Main Crate is empty (no files)
- the Album Crates have sub-crates but no files too
- the Singles Crates (nested on each Album Crate) have files from External Drive
is that your structure ?
If you add a new Crate in SDJ (not inside the Main Crate one), does it show up in VDJ ?
So ..
geposted Tue 10 Mar 15 @ 10:51 am
Ok can you answer me this question??
Where EXACTLY do I point VDJ to when I'm using multiple drives??
As I look more into this a lot of my crates are not showing up yet they are all inside SDJ when I open it up.
I'm on a Mac also.
And I have a _Serato_ folder on every drive and it has a crate and sub crate folder which is making me believe VDJ doesn't see them all.
Right now my file path is /Users/Soundinsurgent/Music/_Serato_
But that's only on my MAIN DRIVE and nothing to do with my external drives.
I'm on a Mac also.
geposted Tue 10 Mar 15 @ 11:11 am
VDJ looks on all drives for crates.
The structure of your external drives is something like this?
D:\_Serato_\Subcrates\mycrate.crate ?
geposted Tue 10 Mar 15 @ 11:30 am
But I can ONLY point VDJ to 1 location. I just tried to tell VDJ I have a Serato folder on my internal and external yet VDJ is only seeing my internal and part of 1 external!!
And if I don't tell VDJ where to look then NO crates show up.
And if it looks on ALL drives for crates as you say then what's the point of me telling VDJ where to look??? This makes no sense to me......
geposted Tue 10 Mar 15 @ 11:37 am
I think you can point to a custom Serato path only for the C Drive.
Normally it will look at the "default" paths for all other Drives.
thats why Adion asked you the path of the Serato folder in your external ;)
So does the external drive look like this.. D:\_Serato_\Subcrates\mycrate.crate ?
geposted Tue 10 Mar 15 @ 12:09 pm
No each drive has it's OWN _Serato_ folder which has a "Crates" and "Sub Crates" folder.
On my Mac it does not use the "C:/" extension, each drive is named like this "Videos pt1", "Videos pt2" and then "TRACKS".
Remote takeover?? 😜
Remote takeover?? 😜
geposted Tue 10 Mar 15 @ 12:20 pm
Just to clear this up:
djdad is correct.
VDJ will look at the custom path, and also automatically the _Serato_ folder on the root of all other drives. The reason for the custom path is so that if your system _Serato_ folder is not in the default location, then you can change it (since that is not in the root of the drive by default, it's usually in your Music folder).
djdad is correct.
geposted Tue 10 Mar 15 @ 6:01 pm
Scott, Checked Huey's computer and paths are OK.
Took his Subcrates folder and was able to reproduce here on my own computer (cross-platform issue).
We will investigate.
geposted Tue 10 Mar 15 @ 6:08 pm
Gotta love that TV program 😜
geposted Tue 10 Mar 15 @ 6:43 pm
Adion has found the problem and it should be fixed in the next available build.
geposted Wed 11 Mar 15 @ 3:26 am
Right on!! 👍
geposted Wed 11 Mar 15 @ 5:32 am
Problem actually made worse now.......
VDJ isn't even reading half of my crates.
geposted Mon 16 Mar 15 @ 10:22 pm
Can reproduce here too. Team will take a look.
geposted Mon 16 Mar 15 @ 11:11 pm
Ok so is this an actul bug with VDJ or is it just my files??
I will say this I use a script to clone my folders which turns them into crates. And yes I do this on both a PC and Mac.
Not sure if that makes difference or not??
geposted Tue 17 Mar 15 @ 2:44 pm
