When i hit the play button on de CDJ >> the song starts playing with very slow start up speed and speeds up after 5 seconds to normal play speed.
What to do or change in the configure module ?
geposted Sat 21 Mar 15 @ 2:16 am
Have a look in advanced options search "rampStartTime" it could be that set that to a small number (0 - 0.2)
Or it could be HW and then I have no idea
geposted Sat 21 Mar 15 @ 2:35 am
The CDJ2000 have dedicated knobs to adjust the start-up and brake speed (VINYL SPEED ADJUST). Those should be set to minimum 0 if you need to have instant play/stop.
If at any case you use those knobs for something else, switch to the default "factory" mapping, set those to minimum position and then switch back to your custom one.
geposted Sat 21 Mar 15 @ 4:05 am
Thx,
gonna try it this afternoon.(Rampstartime)
geposted Sat 21 Mar 15 @ 4:17 am
No result.
Start & stop ramptime 0 >> still slow speed startup song
Problem caused by CDJ2000nexus. Maya USB soundcard connected without USB CDJ2000
>>>OK
>>>OK
geposted Sat 21 Mar 15 @ 7:35 am
The start/stop ramp knobs on the cdj are turned all the way to the left?
geposted Sat 21 Mar 15 @ 10:25 am
Ok, thx to all.
start/stop ramp knobs adjusted to full left >> OK!!!!!
Strange, position of the start/stop ramp knobs doesn't matter on the CDJ2000.
I still have my doubts about VDJ8 in combination with Mac. During the test, second CDJ2000nx lost sound. Had to restart VDJ8.
So, still using VDJ 7.4 (no problems at all)
DJ set in Swingcafé 't Oude Hof : 2xCDJ2000 + 2xCDJ2000nx + DJM2000 + IMac (i7)
geposted Sat 21 Mar 15 @ 1:35 pm
