Topic: Echo Effect no longer responds?
Hey team, this software has been phenomenal I just have an issue whereby all of a sudden the echo effect just no longer works. Whichever version I try the result is the same. This is a mystery as I haven't made any specific changes anywhere.
geposted Sun 22 Mar 15 @ 6:18 am
Working here, how about the strength.
geposted Sun 22 Mar 15 @ 6:56 am
SOLVED NOW!!... I deleted the ini file then reloaded VDJ.... don't remember messing with the strength :-/
geposted Sun 22 Mar 15 @ 7:08 am
