Hi guys,
i have decided to do a reinstallation of VDJ8. The reason is that the sound quality i am getting is not a par with what i had when i was running VDJ 7
Additionally, when i look at the browser of my songs i can see the BPM , however, wjen i load the song unto the platter, the BPM displayed is much different. I rescanned my library and the issue still remains.
I am not sure if a reinstallation will cure this but
The question is reinstall VDJ 8, can i just install over the previuos one? or do i need to uninstall and then do a reinstallation?
Thanks
Thanks
geposted Wed 25 Mar 15 @ 10:17 am
You can try it, but I think that won't help since a plain reinstallation will not affect your settings and database files.
And you don't want to delete this files by uninstalling VDJ, confirm that you want to delete this files, and then do a reinstall.
What build number are you using?
geposted Wed 25 Mar 15 @ 11:00 am
i am on Build 2174.954
geposted Wed 25 Mar 15 @ 11:25 am
When you load the track on a deck, is the Pitch at 0% ?
Prior loading the track to a deck, if you right-click on the track and choose to Re-analyze, does the BPM change ?
geposted Thu 26 Mar 15 @ 10:04 am
Djdad,
Thanks for the response.
Yes, the pitch is always set to zero
if i reananlyse the the BPM, the BPM dosen't change.
An example is i have just looked at Michael Jackson - Thriller. The BPM in the browser is 118.0. I have reanalysed the BPM and it still shows 118.0. However, once i load it on the paltter, it shows 120.75
and before you ask, i do no have 'sync on load' as the other deck has a track that has a BPM of 120.97.
Quite queer if you ask me. This has been happening since i moved to VDJ 8. Never happened on VDJ7
geposted Fri 27 Mar 15 @ 7:03 am
