Topic: error on mac
i've noticed on last few updates when i boot vdj 8 it shows error in both decks 1 & 2, then during the night to the right of the search box it says error in deck 3 & error in deck 4.
is this a bug or how vdj is now supposed to work?
geposted Wed 25 Mar 15 @ 8:34 pm
Its a "cosmetic" bug. Error goes away as soon as you load a track on a deck.
It will be fixed in next beta build.
In the meantime, if you still want to get rid of that "error", set your sound card to 44Khz (from Audio Midi Setup)
geposted Wed 25 Mar 15 @ 8:38 pm
ah ok it's performing fine, just didn't seem right i'll hang fire until the next beta build.
geposted Thu 26 Mar 15 @ 8:19 am
