Topic: Auto Headphones Issues
dydy1PRO InfinityMember since 2006
virtualdj_osx_v8.0.2191.959, has an Auto headphones issue with saving the option Unload or Always as a default option when restarting the software. I am also using a Pioneer DDJ-WeGO controller.
geposted Mon 30 Mar 15 @ 6:44 pm
WeGO controllers have indeed a preset in the definition to set AutoHeadphones to Off as per Pioneer's request. But as soon as you change the setting to whatever value you want, it should use that on the next launch. No ?
geposted Mon 30 Mar 15 @ 9:30 pm
When onload is chosen in the option menu and VirtualDJ is reopened It goes back to the default value no. I am trying to find a way to save it as ONLOAD as the default setting.
geposted Mon 30 Mar 15 @ 10:16 pm
hmm you are right. The setting should only apply on first launch. Reported.
geposted Mon 30 Mar 15 @ 10:53 pm
Thank you much for reporting it. I hope they fix this bug on the next update.
geposted Tue 31 Mar 15 @ 11:56 am
Can you try this ?
Once VirtualDJ is launched, you should get a pop-up Detection window.
Click to enable the "Don't show again" option.
Close and relaunch.
The Pop-up window should not appear now and you should be able to change the Headphones setting, which will be now saved across sessions.
geposted Tue 31 Mar 15 @ 3:52 pm
I will try your suggestion above and see what happened. I will let you know how it went.
I just tried your suggestion above & It is now retaining and saving the option ONLOAD for AutHeadphones when the software reopens! Thank you so much for your help.
geposted Tue 31 Mar 15 @ 3:54 pm
