Topic: REALLY obscure bug
I've found a bug that is really tricky, in normal use you'll never see it but messing with APOI hotcues like I am, it occurs regularly
I'll explain the symptom
Even if a hotcue exists pressing the skin button or scripting to call the hot cue, rewrites the hotcue and it will do this until I restart V8 (even on non poi laden tracks)
Explaining what is going on with the Apoi will take too long, but I can send my files if needed (keyboard mapping, database entry, track, instructions to recreate the bug)
geposted Tue 31 Mar 15 @ 8:32 am
APOI ?
geposted Thu 02 Apr 15 @ 4:25 am
Action POI?
geposted Thu 02 Apr 15 @ 4:50 am
Indeed Action POI, I think out of good manners I turned off crash reporting , with 1300 Apoi, things are a bit "wobbly"
geposted Thu 02 Apr 15 @ 11:16 am
