Is there a way to keep the key detection showing the note instead of the number? (standard skin)
Even if I change it's not stored when I close VDJ8.
geposted Thu 02 Apr 15 @ 3:38 am
Only if you change/edit the skin.
Unzip the VirtualDJ 8.zip file you will find in Documents/VirtualDJ/Skins folder and open the 2 Decks.xml file with a Text Editor.
Search for .. get_harmonic
You will find 2 "blocks" that look like..
<textzone>
<pos x="+433+31" y="+63"/>
<size width="32" height="15"/>
<text size="15" color="#E1E1E1" align="left" action="get_harmonic"/>
<text size="15" color="#E1E1E1" align="left" action="get_key"/>
<text size="15" color="#E1E1E1" align="left" action="get_key_modifier"/>
</textzone>
Change the order of the lines so that the one you need to be displayed by default is 1st
Save, update the zip and relaunch.
<textzone>
</textzone>
geposted Thu 02 Apr 15 @ 3:52 am
Great!
Thanx for fast and precise support!
This is the reason why I love VDJ. It can be changed and edited to suit everyone's needs through the skin and controller mappings.
Happy easter!
Happy easter!
geposted Thu 02 Apr 15 @ 4:11 am
