Hi All,
I am currently editing (Read: Re-arranging) the browser-zoom skin (4 decks) that I downloaded a while back.. Only thing is, I want to change the colours in the browser - But I can't find the code for it anywhere in the XML file.. Does anyone know where it is??
Once I know where it is I am capable of editing it manually - I spent a couple of hours yesterday doing everything else I wanted to do and It's all going to plan so far :)
Thanks a lot,
Thanks a lot,
geposted Fri 03 Apr 15 @ 8:02 am
Just search the xml file for <browser
geposted Fri 03 Apr 15 @ 8:04 am
I did, and I can find the code that sets the position of the browser - but it just looks like this - there are no colour options at all in any of the code for the browser..
Thank You!!
Thank You!!
geposted Fri 03 Apr 15 @ 8:10 am
From the skin wiki:
The <browser> element
The browser element sets the space that will be used to draw VirtualDJ's Browser (Folders list, Songs List, Sideview, Info). More than 1 <browser> elements can be also displayed, and those can be also numbered. Custom Browsers is also possible using <split> panels. Browsers can be nested in panels and have visibility=""
The syntax of the browser element is :
<browser toolbar="yes" effects="yes" >
<pos x="13" y="547" width="1898" height="525" />
<colors background="#2E2E2E">
<toolbars background="#2E2E2E" text="#2E2E2E" iconbackground="#2E2E2E" border="#2E2E2E" />
<lists background="#2E2E2E" stripes="#2E2E2E" over="#2E2E2E" overstripes="#2E2E2E" selected="#2E2E2E" focus="#2E2E2E" text="#2E2E2E" overtext="#2E2E2E" selectedtext="#2E2E2E" focustext="#2E2E2E" automix="#2E2E2E" livefeedback="#2E2E2E" download="#2E2E2E" scan="#2E2E2E" button="#2E2E2E" buttonover="#2E2E2E" buttonselected="#2E2E2E" buttonactive="#2E2E2E" insert="#2E2E2E" />
<grids background="#2E2E2E" over="#2E2E2E" selected="#2E2E2E" focus="#2E2E2E" text="#2E2E2E" overtext="#2E2E2E" selectedtext="#2E2E2E" focustext="#2E2E2E" stripes="#2E2E2E" overstripes="#2E2E2E" selectedstripes="#2E2E2E" focusstripes="#2E2E2E" label="#2E2E2E" />
<columns background="#2E2E2E" text="#2E2E2E" />
<scrollbars background="#2E2E2E" button="#2E2E2E" />
<info background="#2E2E2E" stripes="#2E2E2E" text="#2E2E2E" label="#2E2E2E" artist="#2E2E2E" title="#2E2E2E" />
<search background="#2E2E2E" border="#2E2E2E" selected="#2E2E2E" text="#2E2E2E" cursor="#2E2E2E" />
<prelisten background="#2E2E2E" border="#2E2E2E" selected="#2E2E2E" cursor="#2E2E2E" button="#2E2E2E" buttonbackground="#2E2E2E" buttonselected="#2E2E2E" />
</colors>
<font size="20" />
<fontheader size="20" />
<fontgridtitle size="20" />
</browser>
Only position is required, all other elements are optional.
<colors background="transparent"> can be used to create a transparent background.
Note that in this case, it is strongly advised to set skin breakline and breakline2 in order to prevent issues when stretching the browser.
you can find the skin wiki right here:
http://www.virtualdj.com/wiki/SkinSDK8.html
with best regards
Music234
</colors>
<font size="20" />
</browser>
with best regards
Music234
geposted Fri 03 Apr 15 @ 9:17 am
So do I just copy in the bits about colour etc. after the <pos...> bit on a new line??
Thanks again :)
Thanks again :)
geposted Fri 03 Apr 15 @ 9:24 am
Have a look at a skin mod that I did here
geposted Fri 03 Apr 15 @ 9:27 am
Haha.. Nice :)
Figured it out now - thanks everyone :)
Screenshot attached - I don't intend on publishing it as I havent added anything as such.. :)
geposted Fri 03 Apr 15 @ 10:04 am
I have now finalized the skin.. Comments/Recommendations welcome :)
http://www.virtualdj.com/addons/17035/Stripped_Down_4_Deck_Skin_(VDJ8).html
geposted Sun 05 Apr 15 @ 2:19 pm
If you wish to share a version 8 Skin, then you will need to upload it to the correct section... http://www.virtualdj.com/plugins/upload.html
Once you do that, the Team will review your skin and will make it available for users once the evaluation is completed.
Thanks
Thanks
geposted Mon 06 Apr 15 @ 5:56 am
Sorry.. Thanks though :)
geposted Mon 06 Apr 15 @ 6:52 am
