I'm on the most recent beta (2191), and saving edited bpms isn't working, neither off deck nor on deck.
It's a recent bug (discovered just now) but I can't tell you which build last worked.
geposted Sat 04 Apr 15 @ 5:10 pm
Can you try with 2915 ?
I just tried with a track, changed BPM, added 2nd Beatgrid anchor etc and it was saved.
Which parts doesnt work exactly ? Steps to reproduce ?
geposted Mon 06 Apr 15 @ 5:12 am
Ah, I see what happened (I'd forgotten that the bpm editor doesn't like speedcore), it's when the bpm is high (240+) (yes that is still music :-) )
Just write a number 240+ into the bpm editor and it won't save.
I could just remember the 240 limit and edit at 1/2 speed then use set_bpm 200% like I had in the past, I just forgot.
geposted Mon 06 Apr 15 @ 5:24 am
