Today I was playing with the sample editor and struggling to see what buttons pressed there. (All white)
Should be an easy fix for you.
geposted Sun 05 Apr 15 @ 4:11 am
geposted Sun 05 Apr 15 @ 6:23 am
That is OS and Theme related, not a VDJ thing.
On Win 8.1 standard the selected buttons are blue.
geposted Mon 06 Apr 15 @ 5:00 am
Really, the VDJ interface should be independent of any themes, for exactly this reason.
I reported this in the early days of VDJ 8, when I found that it wasn't clear which button was selected in the audio config window.
geposted Mon 06 Apr 15 @ 5:10 am
Fully agree with Groovindj. I use the classic theme in Windows 7 and VDJ should really handle that.
This is not a free software, we paid $$ for it and should be able to see what buttons are pressed or not.
geposted Mon 06 Apr 15 @ 7:10 am
I think you can personalize the colours of the OS to your needs.
If you need advanced options, have a look at
HKEY_CURRENT_USER\Control Panel\Colors
HKEY_CURRENT_USER\Control Panel\Desktop\Colors
HKEY_CURRENT_USER\Control Panel\Desktop\WindowMetrics
geposted Wed 08 Apr 15 @ 3:56 am
Thanx
That could be a solution!
geposted Wed 08 Apr 15 @ 4:52 am
