Forum: Old versions
Topic: Intel 4000HD and Nvidia 640m on laptop problem.
Hi.
I have laptop with i5 procesor with Intel 4000hd and Nvidia 640m graphic card. The problem is, that i can not select Nvidias card as main for VDJ. I have tryed everything, but i can not see Nvidia in VDJ settings. There is always Intels card. (Latest drivers instaled)
Do anybody have same problem, Or (best) a solution.
Thank you, Tomas.
geposted Mon 13 Apr 15 @ 8:32 am
RobRoyPRO InfinitySenior staffMember since 2012
Do you use V7 or V8 ?
geposted Mon 13 Apr 15 @ 8:42 am
Using VDJ8 and windows 8.1 64-bit.
Thank you.
geposted Mon 13 Apr 15 @ 10:28 am
Please open your Nvidia Control Center and assign the Nvidia card to the V8.exe.
Switching between the onboad and the dedicated card works not perfect on some systems atm.
Please have also a look how much memory is used for Videoplayback in your settings/ options/ videoMaxMemory
Sometimes the Intel is displayed but the memory of the Nvidia is used.
you can also use this plugin to check which card is used.
http://www.virtualdj.com/plugins/index.html?category=effects&search=fps
The Dev Team is aware of the issue and sure they working on it
geposted Mon 13 Apr 15 @ 10:49 am
Thank you for quick reply. I have already switched to nvidia for V8.exe file but in settings i see Intel 4000 hd. Max memory is 981 witch corespond with 1GB of nvidia, so i dont know. I will try plugin recommended by you and let you know later today.
Thanks again.
Best regards Tomas.
geposted Mon 13 Apr 15 @ 10:56 am
acw_djPRO InfinitySenior staffMember since 2005
Hi,
To ensure Nvidia would be taken in this dual graphics computer, I suggest you to get the latest:
1) Bios computer update
2) Chipset drivers
3) Video Graphics drivers
All this from the manufacturer website. Then In Nvidia control panel, ADD "virtualdj8.exe" as a high performance program.
geposted Mon 13 Apr 15 @ 11:41 am
@acw_dj
I did all as you sugest. But still the same.
Thanks Tomas.
geposted Mon 13 Apr 15 @ 12:02 pm
News from the FPS Tool ?
geposted Mon 13 Apr 15 @ 12:35 pm
Do you have a external monitor connected?
Is this a HDMI or VGA or Display port???
geposted Mon 13 Apr 15 @ 2:00 pm
Got this from FPS
geposted Mon 13 Apr 15 @ 2:04 pm
Output is to laptop only for now. Than i will use HDMI, but there was same results with external monitor connected via HDMI.
geposted Mon 13 Apr 15 @ 2:07 pm
geposted Mon 13 Apr 15 @ 2:18 pm
