Forum: Old versions
Topic: Korg Nano PADII USB mapping needed...
djezmgsPRO InfinityMember since 2014
now hopefully, when I hit Post, it will post this all laid out nicely so here goes...
Hi all wondering if i can get some help...
my Korg Nano pad arrived today and installed the drivers. and windows has detected it just fine...
with that said What do you all know about midi mapping a Korg Nano pad in VDJ.8.Pro?
I need to use the pad as a "Trigger" as I already have a Hercules 4-mx controller and its set up, and works just fine...
What I would like to happen is, lol to set up the nano pad II to Trigger "effects and samples only". and maybe some X/Y BS on the effects
here's what I been looking at and an idea what i like to do with the nano pad triggers:
in VDJ mapping
Nano pad: Trigger samples only (push button one time, sample plays and stops, not sure how to write the VDJ syntax??)
Key: Action/Syntax/script
0 Button 53 Play Sample Back1 Slot 1
0 Button 55 Play Sample Back1 Slot 2
0 Button 57 Play Sample Back1 Slot 3
0 Button 59 Play Sample Back1 Slot 4
0 Button 61 Play Sample Back1 Slot 5
0 Button 63 Play Sample Back1 Slot 6
0 Button 65 Play Sample Back1 Slot 7
0 Button 67 Play Sample Back1 Slot 8
Nano pad : Trigger Efx:
can we set up the X/y pad as "Control" for the affected "ON"effects...
meaning, How much or how little of the effect we can use, like a effect Control gain via X/Y? (just like a Korg Kaos pad)
Set up effects:
0 Button 52 Effect_active_Phaser (Control with X/y pad ??)
0 Button 54 Effect_active_Flanger (Control with X/y pad ??)
0 Button 56 Effect_active_Wahwah (Control with X/y pad ??)
0 Button 58 Effect_active Echo (Control with X/y pad ??)
0 Button 60 Effect_Echo (Control with X/y pad ??)
0 button 62 Effect_ Stereo Pan (Control with X/y pad ??)
this is what I would like to accomplish lol many thanks for any help...
https://www.mixcloud.com/dj-mgs/
geposted Wed 15 Apr 15 @ 3:23 pm
