hi there i updated my vdj 8 mac version to the latest build but its not giving me sound out of my laptop ,and when connecting it to my wego controller it works but no sound out ,and everytime i load tracks it gives the gain of the track -infinity and to the max right of the knob,and the sound preferences are all correct,and when connecting it the internal sound card i still have the same prob ,it plays the track but no sound out and the mixer signal is not flashing ,and i installed previous builds still doing the same but the gain knob giving no gain indicator and no signal of the mixer in vdj,it is really weird i can't find wats the problem
geposted Wed 15 Apr 15 @ 5:11 pm
i tired the same thing to vdj7 but my ego didn't show up in the mappers,and i tried the internal sound card it keeps giving me beach ball, i also connect the serato dj after closing vdj to my wego,it work for a while then stared to freeze ,i also changed the usb cable but still the same prob with serato dj ,so can't figure it out wats the prob
geposted Wed 15 Apr 15 @ 5:19 pm
I'm so sorry but please do not open here a TOPIC.
Please be so kind and insert at the related Beta Builds Regression Bugs TOPIC (BUILD 2204 - BETA) your post.
http://www.virtualdj.com/forums/200065/Beta_Builds_Regression_Bugs/BUILD_2204_-_BETA.html
I will move this TOPIC to VirtualDJ 8 bug-report Forum and send you a PM where to find :-)
http://www.virtualdj.com/forums/75/VirtualDJ_8_bug-report_Forum.html
Thank you for understanding
TOPIC moved
TOPIC moved
geposted Thu 16 Apr 15 @ 2:48 am
It is possible you simple use the wrong soundcard setting.
Please be so kind and check page 78 & 90 to see how the settings should look like for internal and controller soundcard use.
http://www.virtualdj.com/images/pdf/VirtualDJ8_User_Guide.pdf
geposted Thu 16 Apr 15 @ 2:55 am
all the sound settings are correct and no sound from vdj even from the internal sound card,it plays with out sound and no signal in the vu meter,the gain knob either with indicator to the maximum right or no indicator so weird ,i think its something in installing the software,am wondering how to remove it and then install it again,maybe some files are lost while installing
geposted Thu 16 Apr 15 @ 6:27 pm
also when i press restore default options in the preferences it freezes really strange!!!!
geposted Thu 16 Apr 15 @ 6:34 pm
Delete the settings.xml from documents/virtualdj folder , relaunch and should be fine
geposted Fri 17 Apr 15 @ 2:40 am
thank you Dj dad it worked when i erased the xml file for the settings it was the one causing the whole problem and the software not working you made my day :)
geposted Fri 17 Apr 15 @ 7:45 am
Thanks DJ Dad it fixed my problem too! :)
geposted Mon 15 May 17 @ 2:10 am
Can you help me Djdad?
I have a Numark Party Mix controller and i open my virtual dj le and it will play the music but i cant hear it.
Whats the problem?
Whats the problem?
geposted Thu 13 Jul 17 @ 8:28 pm
Hi i have bin having this problem with virtual DJ version 8.The problem is that evrey time i plug in my mixer the sound gets cut off so i hope you can do something about that so please get back to me soon as possible.
geposted Sun 07 Jan 18 @ 8:32 pm
This is for an old version of VDJ
Anyway... Please explain your setup. Since the mixer is normally what handles the audio, it seems natural that it will affect the audio when connected/disconnected. So you probably mean something else
geposted Sun 07 Jan 18 @ 8:54 pm
Hi! am beginner and am having same problem! i downloaded Virtual Dj software, and when i play a song, there is no sound coming out of my computer! please help!
geposted Sun 01 Apr 18 @ 12:30 am
That's not the same problem at all
But the first thing you should do is check your audio setup
geposted Sun 01 Apr 18 @ 8:01 am
