Does VDJ 8 store the previous update history anywhere in settings. I've looked all over and didn't see it any where. I did an upgrade and have some minor issues with the upgrade and was thinking about rolling back, but can't remember the previous build.
geposted Sun 19 Apr 15 @ 10:23 pm
There is no build history in the software itself as far as i know but just have a look here:
http://www.virtualdj.com/forums/76/Beta_Builds_Regression_Bugs.html
You will find any changes and inprovements for each build and also some informations to downgrade to a previous build.
geposted Mon 20 Apr 15 @ 1:56 am
I browsed through there before I made the original post with hope It would jog my memory. Should have written the build down for the initial install. I'll do that going forward. thanks.
geposted Tue 21 Apr 15 @ 12:45 am
