-fix some broken netSearch results
-Allow scrolling in effect list drop-down with browser_scroll action
-SamplerOutputTriggerDeck option available with master/headphones audio config as well
geposted Wed 22 Apr 15 @ 8:05 am
Allow scrolling in effect list drop-down with browser_scroll action - isn't working with, browser_scroll +1 or browser_scroll -1 on buttons
I'm not sure if it is an issue, (as buttons can use effect_select +1) I just can't imagine the encoder mapping.
Could custom buttons variations get this treatment also please?
geposted Wed 22 Apr 15 @ 8:36 am
Please add the Reset Sort Order right-click option also in any folders or virtual folder when a order file is present, now I see this option only inside playlists, but I find it very helpful the action browser_sort "Original Sort Order" and with the right click option I think is more intuitive.
Ps
i think it's better to put more info into the language.XML for the action browser_sort, adding for example the "Original Sort Order" example.
Ps
geposted Wed 22 Apr 15 @ 10:44 am
@cioce
Normal folders and virtual folders, there is no order file present for the tracks, the order is set by the fields.
OffTopic
(Quietly fixed the renamed folders going to the bottom I see, nice)
OffTopic
geposted Wed 22 Apr 15 @ 11:07 am
effects Browser scroll? about time ;)
geposted Thu 23 Apr 15 @ 5:08 pm
Has the small master tempo glitch been resolved? When the pitch slider is first initiated a light glitch/crack can be heard in the audio, it doesn't happen on every occassion.
geposted Fri 24 Apr 15 @ 10:15 am
Hey, Bren. Have you experienced this issue with difference latency settings?
geposted Fri 24 Apr 15 @ 6:45 pm
I'm already set at 512 using a DJM2000, I can't imagine increasing this further.
geposted Fri 24 Apr 15 @ 7:01 pm
In this version, left-channel audio meters do not work and left volume fader either, (pioneer aero, Windows 8.1 pro 64bit)
geposted Fri 24 Apr 15 @ 7:55 pm
bagpuss it happen to me to
geposted Sat 25 Apr 15 @ 12:03 am
confirm this, also happens when first deck effect scroll, first initiated/scroll , or loop (rare).
geposted Sat 25 Apr 15 @ 5:23 am
virtual folders are empty, non of my tracks are visible in the virtual folders i made,this happened since the few build updates,i have vdj 8 mac version
geposted Sat 25 Apr 15 @ 6:31 am
If you go back to an older build do they return?
If so which build works?
geposted Sat 25 Apr 15 @ 7:02 am
yes if i go back it works,the build which virtual folders are working is 2191.971
geposted Sat 25 Apr 15 @ 11:00 am
Was playing last night and the decks would gradually stop responding to all commands; MIDI, keyboard, and mouse. Decks 1 and 2 would stop working first, then 3-4. Each set of decks would work for about 30 minutes. Audio wouldn't stop or glitch. Played off a backup a rebooted twice. Still happened.
geposted Sat 25 Apr 15 @ 3:14 pm
After 4 hours, left dish I miss respond with this version, (pioneer aero, windows 8.1 pro 64bit...
geposted Sat 25 Apr 15 @ 7:07 pm
Did it again. Rolled back to 2206 as well...
geposted Sat 25 Apr 15 @ 10:18 pm
yes if i go back it works,the build which virtual folders are working is 2191.971,but i have always to go back to xml file setting and erase it so that it works again!!
geposted Sun 26 Apr 15 @ 7:29 am
